godminus
hola
I have an annoying problem with my 2005 fazer600
I decided to put some new isolairband around the front lights wires since they were all dirty and old.
After doing so (took me about 20 minutes, nothing major), I wanted to check that everything works well. put the key in the switch & turn it into ON position
everything lit up okay. tried to press the start button and then I heared this ticking noise coming from the battery, so I assumed there must be a short or something. I tried to press the PASS button (the one that turns the HIGH BEAM on) and everything went crazy - gauges went offline and online again.
So I unwrapped everything and double checked all of the wires - everything seems to be ok. tried to switch the key to the ON position and this time I get code 12, which says in the manual "Open or short circuit in wiring harness.", START button does nothing but this crampy noise - pressing the PASS button again does the same thing making the guages go offline&online
Any idea anyone??
Thanks
Shai
Any idea anyone??
Thanks
Shai
