04fizzer
I would leave insurance out of it. They are not going to cover a frame failure with no accident, they are only going to note it, and not pay for it if you get hurt.
It is most likely a inclusion, or a scratch that has propagated thru the metal.
Long Long Long drawn out story very short. Metal is a crystal matrix. Any where a cyclic load is present with damage it will attempt to repair itself. That is the common "beach mark" that is present when humans notice parts failure. It is always caused by some sort of stress riser. (usually a inclusion, micro bubble, cut, scratch or notch) The way to stop it is drill a hole at the end. This puts a nice round radius in the metal latice. It cant propagate any more and weld it back.
It could of been stopped a long time ago if it was noticed as a small crack. In reality the frame probably should never of been shipped. If Yamaha does not want to cover it, you are stuck.
Drill, V grind, and weld, or shell out for a new frame. I would not worry about a welded frame at all.
Buy and read this book untill it falls apart. Amazon.com: Engineer to Win (Motorbooks Workshop) (9780879381868): Carroll Smith: Books It will make you a more competent human. You will have a strong basic understanding of what metal is doing, and what you can ask it to do. Its just like having a strong understanding of what you can ask your bike to do when riding. You will tighten and choose fasteners better, and trust what and why you do.
I hope this helps you in some way.
Steve
Cyclical loading is a nasty, nasty thing. Even though a part seems strong enough (number wise), you throw cyclical/fatiguing stresses in there, and you're looking to cut the strength in HALF. This phenomenon was first studied after train axles were catastrophically failing (is there any other way for a train axle to fail?), even though the axles were designed properly by the standards at the time.
