woomertj
Hello - I am the proud owner of a "new to me" 2004 FZ6. Love the bike and it's in almost new condition - only 8800km. It came with a Givi V46 topcase and I decided to add this kit to it (V46 Top Case - LED Kit (TS)). I got it installed last night and got it working. Signals, brake, running lights, all worked. That said, I've had the problem that the 10A tail fuse (runs the signals and rear running light) is now blowing. It's happened twice. The first time I popped the fuse when testing the connector that runs to the taillight to determine which wire was taillight and brake light. I had my meter lead on the connector and accidentally bridged two of the prongs inside. I heard a small pop and found that fuse was blown. No problem. I replaced it, continued put it together, test, and no problem. I then went for a ride. After about 15 minutes, I went to signal and they weren't working Fuse blew again.
I was unsure on how to ground the harness. There were 5 wires, one for 12v constant power, brake, left, right and ground. It didn't say the best way to ground it, so I just found a bolt nearby on the frame and did that. I'm an electrical rookie, so this may be the issue. What is the best way to ground? The kit included an extra posi-connector which makes me think there is a wire I should attach to, but the instructions were unclear. Is this my issue?
Thanks!
Thanks!
