Mr_McBride
The Cartographer
subscribing as I'm interested in the results of this mod.
You really should check the temperature of the voltage regulator. All of that increased capacity is being discharged as heat, and it won't be long until the nylon wire connector melts or the regulator simply burns out.OK so the stator came back.
Same numbers....
I have the DGV installed and the meter is showing numbers between 14.4 and 13.6 while I had it running.
However one thing I noticed now is how hot the ignition cover is getting.
I ran Dad's FJR for a while and then checked the temp with a temperature gun and got around 140 degrees off the side of the cover in the center.
My bikes cover was around 120ish after sitting for a few minutes, however the cover was much hotter to the touch still than Dads was.... not sure why.
Any one on here have a temp gun and mind getting a reading just to see?
-bryan
If the voltage regulator is the aluminum (?)finned device that is bolted to the underside of the frame just below the seat behind the motor...then the temp is fine. It did not get hot when I was running it. I was keeping an eye on that.
Not sure where the regulator is on our bikes, or what that box does but I thought it had something do with the charging system. And the fact that it has fins on it makes me think that it must get warm!
-bryan
I just read this entire thread - my head hurts.
