z2345
Thought I'd share:
1 2 3 4
E .203 .216 .203 .152 .241 .215 .216 .216
Good: .23-.3
1 2 3 4
I .140 .140 .140 .140 .140 .140 .165 .165
Good: .13-.2
Questions:
Does the direction that the crankshaft is spun in 180 degree intervals to measure each cylinder matter? The manual states CCW, but when I started with #1 TDC on the compression stroke (cam lobes facing away from each other) as stated in the service manual, when I go 180 CCW, the lobes are slightly compressing cylinder #2 valves. When I go CW, each cylinder's valves are completely closed (how I assume the clearance should be measured).
So now I have to take the cam's off, and see what pads are on there to replace them with slightly smaller ones, correct?
Thanks!
1 2 3 4
Good: .23-.3
1 2 3 4
Good: .13-.2
Questions:
Thanks!
