Valves needing adjustment
bpchura
STL
Just checked my clearances and it looks like there are a few that need some adjustment. Can anyone confirm that the size is in fact 9.48mm? I was going to order the hotcams shim pack to make it easy to get them all within spec.
For anyone wondering the clearances are below.
Thanks!
1 2 3 4
I .15 .15 .13 .15 .15 .15 .15 .15
E .25 .2 .2 .23 .2 .2 .23 .23
If I got the whole set, I would change the .2 on the exhaust and most likely bump up the .23 to .25 while I was at it.
bpchura
STL
Sorry I guess the formatting on my little chart got weird when I posted it. You can figure out what I mean though! :D:D
thisisdylan
California
Valve clearance (cold)
Intake valve: 0.13 - 0.20 mm (0.0051  0.0079 in)
Exhaust valve: 0.23 - 0.30 mm (0.0091  0.0118 in)
the only ones out of spec are the 0.2 exhaust ones. just buy some .05 shims for those two. the .23 exhausts are still in spec.
