Tailgate
If you would like to read an in-depth---and interesting---analysis of breaking in a motorcycle engine (or any 4 stroke) click this link: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
What brand do you run now mate?Just got tired of the excessive noise with the factory Yamalube and desided to swithch it over at 300 miles. It gets changed every 1,500 from there on. No real reason other than personal preference.
The only reason that oil ever needs to be changed is because it becomes dirty. The lubrication qualities of oil will remain the same (and that's why used oil is sometimes recycled). If you're changing clean looking oil and ahead of recommended intervals consider this: you could instead be spending more time riding and spending more dollars on mods or something.
Synthetic oil hides your 13mm socket and puts superglue on your earplugs. Synthetic oil will scratch your face shield and make your gloves shrink two sizes the night before track day. Synthetic oil will then steal your neutral and sell it for $1.25.
So let's be careful out there!
I know that you may be considering the use of synthetic oil in your bikes. But you really should Very cautious of synthetic oil! It can do terrible things both to you, and to your bike.
I know that you may be considering the use of synthetic oil in your bikes. But you really should Very cautious of synthetic oil! It can do terrible things both to you, and to your bike. Synthetic oil will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system. It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action.
Then it will leak onto your kickstand causing it to retract automatically and without warning, dropping your bike flat on the rocky ground! But that's not all . . . . Synthetic oil will round off your gears and spin your bearings. Synthetic oil will also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and then she will never ride with, or sleep with, you again. Synthetic oil coats your oil sight window with a whitish pro-emulsification additive that is both non-removable and highly corrosive. Synthetic oil will completely leak out onto the ground overnight, force your favorite dog to drink it at gunpoint, and he will then die a slow horrible writhing death.
Synthetic oil will wear out your tires and make your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam all your zippers shut. Synthetic oil will contaminate your gasoline causing your bike to stall on railroad tracks and accelerate uncontrollably near police cars. Synthetic oil will make it rain during rallies and on every weekend. It will causing your cam drive to jump teeth and break your valves to bits. Synthetic oil chemically weakens desmodromic valves and causes the clearances to change every sixteen miles. Then it melts the black soles of your riding boots night before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose. It also causes your swingarm to crack, your studs to break, and your rotors to warp. Synthetic oil then voids your warranty by changing your odometer reading to 55,555 overnight. It also dries out your wet clutch and wets your dryclutch. It makes your clutch cable or slave cylinder seal fail in the heaviest traffic on the hottest day of the year while putting an angry wasp in your helmet for good measure.
I did accuse my CX500 of selling gasoline at night though, but it turned out to be leaky float bowl gaskets. Funniest post I have seen in a while.
We've had a few "Oil Threads" so far:
http://www.600riders.com/forum/fz6-technical/844-sorry-another-oil-thread.html
http://www.600riders.com/forum/fz6-technical/224-what-best-oil.html
Personally, I use Rotella Synthetic and the Pure One filter.
Ok, that is what I was looking for, very informative. Is the PureOne filter the PL14610? I really do not want to pay $12 for the Yamaha filter. I have used synthetics in the past, no problems, ever. I use German Castrol 0w-30 and a PureOne filter in my car, so if the FZ6 uses the PL14610, then my car and bike will use the same filter. Thanks!!
