Recluse420
My grips stopped working and we are about to be in the low 20's and mid 30's next week any ideas how to trouble shoot this? Am I looking for a fuze or something? Thanks in advance
Look for an inline fuse on a wire coming from the positive terminal of the battery. The fuse could be blown. Also check that that system has a good ground. Then if the fuse is blown you have to figure out why. Next would be the controller. Check to see if the controller is providing current to the grips. If that controller is providing voltage then the grip filaments may be defective. You can disconnect the grip heaters and see if they have continuity.
Question: where did you tap it into? Straight to battery or into the ignition? If so, can you share where and how, spares me some time searching
Thanks.
So you can connect the positive either to the inline fuse or to the running light?
How significant is having the relay?
I got the grips, and the instruction are simple if to go directly to the battery. However if to run it thru the relay it getting kind of confusing. What do you connect to the relay connectors numbering as 85, 86, 87 and 30?
