Cleaned the throttle bodies and checked for leaks (all of them fully seal).
However, I didn't manage to do the timing as planned.
I set it with the timing marks lined up as shown in the manual, lightly screw in the tensioner, then start to manually rotate the crank clockwise. It rotates as it should until 280-300 degrees then it is stuck, and the chain on the exhaust side is very tense. If I remove the camshafts so that the chain gets loose, it will rotate past that point with no issues.
It's not the guides- they're positioned correctly. It's not the manual tensioner - before the rebuild I set it the same way and it worked fine, and I've also tried multiple times just to make sure (from loose enough that it skipped, to medium, and to tight), so what the hell is it?
While I am writing this it came to me that maybe I should give it 1-2 links more slack on the exhaust side- what do you think? There is no reference that I can find anywhere regarding the right chain slack that should be on the exhaust side. I'm not sure how well I'm explaining this, so please check the attached picture.
But thinking again- giving it more slack should alter the timing, so that's not good either...
