- Joined
- May 6, 2014
- Messages
- 2,518
- Reaction score
- 2,809
- Points
- 113
- Location
- Amongst the Twisty Roads
When you clear the intermittent headlight issue, you may also solve the tach issue as well.
Maybe, but I doubt it. The gauge lights are always on, as they should be. I figure its either that the coil signal wire is bad or the tach is bad. The headlight issue seems to be the high low switch, but not 100% on that.When you clear the intermittent headlight issue, you may also solve the tach issue as well.
My SV1000s kills the headlights on starter press. I never investigated the circuit but imagined the headlights were unloaded using a relay to open the headlight feed or ground during starter operation.The intermittent headlight thing was fun. Turns out that the start button interrupts the headlights - at a different press depth than the starter engages. The starter button was sticking part way in - enough to disable the headlights but not enough to fire the starter. Next need to trace the tach wiring and try to determine if it is a signal issue or if the gauge is just bad.
Holy Cow!! I think you just identified an issue that I was having with my '87 FZR1000. I would start it up, but have no headlights. Figured out if I wiggled the starter button up/down with my thumb, the headlights would come back on. This went out for several times during the winter - I never took it apart - but then suddenly it stopped being an issue (all I did was shoot down some air from my compressor, which did not immediately affect it) - "fixed itself". But I was curious as to why the headlights were in-line with the starter. Thanks man!The intermittent headlight thing was fun. Turns out that the start button interrupts the headlights - at a different press depth than the starter engages. The starter button was sticking part way in - enough to disable the headlights but not enough to fire the starter. Next need to trace the tach wiring and try to determine if it is a signal issue or if the gauge is just bad.
Old farts can still see that hi wattage, wire wound, ceramic encased resistor, mounted on a firewall! When the starter was engaged that resistor was bypassed, adding current/voltage during the start cycle. When that starter is engaged there is a voltage drop. To compensate they designed the circuit to run normally through that resistor and during crank they gave it a boost.In the olden times automotive, they used to put a ballast resistor in series with the coil, and bypass it when the ignition switch was in 'start' position. Sort of similar purpose. You want all the juice you can get when cranking the engine.
Yup ripped a lot of those out of old(er) cars when doing HEI conversionsIn the olden times automotive, they used to put a ballast resistor in series with the coil, and bypass it when the ignition switch was in 'start' position. Sort of similar purpose. You want all the juice you can get when cranking the engine.
