1990dtgl98
Edit: Solved the puzzle myself!
the link is still missing on your mod page.
I do have one more question. Say I wanted to go to a 4300K color temperature as opposed to what they come with at 6k.
Are the bulbs the same as the socket they drop into? AKA is one an H4 bulb and the other an H7, or do they use some standard HID bulb such as a D2S/D1S bulb?
The bulbs that go into the projector is a D2S-bulb with the wiring stuck to it. In other words, no: The bulbs are neither H7, H4, etc. You can go for a normal D2S-bulb in the future, but then it's necessary to get a thingy like this:
Hey Capo, that plug shown in your post......would it fit in the HID socket (pictured on the first post of this thread)?........or was that just a generic picture for what you were saying?
hi there, you got yourself some nice HIDs cum angel eyes... but from your eBay link, it seems that it was closed... wonder could someone kind enough to let me know the eBayer ID so that i can look into his/her store? thanks!
All done. SICKEST MOD EVER! Huge improvement at night! I need to fine tune the horizontal aiming a little to get rid of a dark spot we created by screwing with the adjustments and had to aim the housings WAY down from stock, but all is good. I do not recommend this mod if you are not freaking good at wiring. It is a wiring nightmare but worth it.
Pics tomorrow.
Pics tomorrow.
Thanks for the update. Looking forward to doing this mod, soon as my headlights arrive.
I've got the cable for the dual BD034 headlight mod, would I use that cable to get dual low beams and dual high beams?
Not sure how Mr. Krid wired his up, but I had the dual headlight mod prior to going HID, and the wiring is totally different.
I basically used the stock low beam wiring to activate two relays wired directly into the battery (HIDs use lower power than stock low beams, but will initially draw a little higher 'til warmed up). The stock high beam circuit is powerful enough to drive the shutters used to open up the full on beam pattern.
I used Infiniti G35 projectors/ballasts, so I didn't have the "angel eye" function to power, but I imagine that could come off the low beam circuit too.
P.S. While you're in there, definitely add the pod lamps. Very little extra effort for very nice effect.
