bigborer
Thanks guys!
So the issue was too much slack in the chain, or what?
With the cams out, all the valves are closed.
With the trigger wheel at TDC the #1 piston is at TDC. That said you are fine. Its the cam timing in relation to the piston position that determines which cylinder is firing.
You are correct- this is a flat plane engine so #1 and #4 are both up, and #2 and #3 are both down
Does the crank turn pretty easy by hand?
Yes, and in any direction
Edit:
What direction were the cam timing marks pointed when you dropped them in? 180° apart yes? Exhaust pointed forward, intake pointed to the rear.
Yes
There should be ZERO slack from the intake to the exhaust; there should be zero slack from the exhaust to the crank. This is a pull system. The only slack that should exist is from the crank to the intake where the cam tensioner goes.
Read some of my posts in the valve adjustment thread.
I offered a lot of detail to help other members on this same topic.
I'll read that as well
Should I tighten the exhaust cam before passing the chain to the intake cam?Plus 1 ^^.
Make sure there is NO SLACK between the crank and EXHAUST CAM, NO SLACK between the CAMS.
So start with the crank on TDC, run the chain to the exhaust cam (it's taught and marks line up).
Then to the intake cam, nice and taught-mark lined up with the head.
Then take up ALL the slack with the tensioner..
