- Joined
- May 8, 2008
- Messages
- 15,358
- Reaction score
- 1,605
- Points
- 113
- Location
- San Diego, Ca.
So im now going through my insurance to get repairs and it went from a rewire to have a code 19,
As i have insurance and comprehensive doesn't affect your rate i decided to file.
rewires done and shop now tells me a second file is going to have to placed because the wiring harness was pinched and it fried the ecu, and Neutral Safety switch. so now i need a California edition ECU and a NSS.
All due to someone messing with something thats not theirs, ill never understand.
Looking for a california ECU and a neutral safety switch if anyone has one that works let me know thanks![]()
There's a starter cutout interrupt relay assembly that has diodes that are easy to blow when shorting the wires to the ignition. These wires were probably shorted when they were cut. If the ECU doesn't get the correct signal from the starter cutout assembly the ECU may appear dead and not function. You may replace the ECU only to find it was okay.
The unit processes logic from the clutch lever switch, side stand switch and neutral safety switch.
Sent from Moto's Droid using Tapatalk 2 :mikebike:
