SamuraiMark
n00b++
My 2006 FZ6 (FZS6V) has learned a new trick:
Bought it used in 2011 with ~9K kms on it. I've put ~30K kms on it since. Regular maintenance by myself and local shops. New plugs in Q2 2012, new battery in Q2 of 2014. Until recently, no issues with the bike.
Two Wednesdays ago, leaving work, the bike would not start. It had started just fine that morning and gave no indication of any problems. When I tried to start the bike that afternoon, it would not fire up. Everything sounded normal (normal ignition / starter sounds) to me. There is plenty of juice in the battery and it seemed to be cranking fine. After about 5 - 10 minutes of random leaning on the ignition, it finally fired up. I drove home and there were no other indications of problems.
Between two Wednesdays ago and last Friday it ran fine. It got me to work every day and last Thursday I was out for a full day of riding with numerous stops/starts. No issues.
Last Friday it pulled the same stunt. It was fine going to work. At the end of the day it would not start. This time I was stranded for a good 45 minutes or more. Again, it eventually did start but I almost killed the battery ... drained it to the point of getting error codes on the display. I was about to abandon it and cab home but gave it "one last chance" and it finally fire up.
In both cases, when it did start, it was as if nothing had happened. It just started normally, ran normally, and away I went.
I don't think this is related, but the idle was low. Around 1K rpm. I adjusted the idle back up to around 1300.
Not having much of a clue I am imagining:
- issues with the plugs and/or ignition wires? Do they need replacing? Are the plugs gummed up from some other problem?
- issues with fueling?
Between the first and second failures, it was just in the shop for new tires, and I had the oil & filter changed at the same time. Mentioned the problem to the mechanic but with nothing specific to look at I took it home with plans to bring it back if it happened again. I'd like to narrow down possible causes before taking it back to the shop.
I'm reviewing my Haynes & service manuals, but any pro-tips are greatly appreciated.
Cheers,
Mark
Cheers,
Mark
