domination2727
Shinigami
Yea more them likely is the case. I think i get how its working and think i can work with this.. Both reflectors are the same just one has a different opening then the other. So what ill do is the orignal h4 socket ill remove one power lead and route it to the h7 socket. Ill modafiy or change the h7 socket to an h4 socket or a simalure bulb type just with 2 elements and make the high beam side attach to the h7 for highbeam and expand the low beam wire to the 4 socket so it only lights the low beam on the h4 bulb. I think that should work. When i do it ill post pictures especialy if it works well
I’d be highly interested to see how that works out. I just ordered a LED h4 and h7. But if I can get it to run 2 H4 bulbs low/high that would be way better.
