Voz
Hi, just been cleaning my throttle tube and lubing cables and general cleanup as I was experiencing binding which turned out to be the rusty bars, cleaned and greased, all good.
I checked the open and close cables worked ok and sprayed in a bit of WD40 for good measure, they were opening and closing the throttle no probs.
I put the throttle cables back on and screwed together, I got about one turn of throttle then nothing. Checking the cables down to the carbs I find that the butterfly or whatever it is will not turn, the cables are loose. I have tapped it lightly with a large screwdriver but it won't budge.
I defo had the cables in the correct order and seated properly in the housing.
