Putting it back together after doing the bd34 cable.
Silly question.
When I wire the HID up, should they light up when I turn on the bike? Or only when I fire up the bike?
thx
I have mine on a switch, but it should come on when you fire up.
Silly question.
thx
Silly question.
thx
Projectors and ballast are good, swapped those. Maybe controller, going to swap that now.
I've took all the connecting wires apart to start again.
Here's what I have from the H4 side to the h7 side, a wire connecting the 3 locations matching it on the h7 side.
H4 Side, factory harness with 3 cables. Took the Left postion factory cable out of the h7 side.
Got a volt meter to check things again.
green/spotted orange wire for the mod
you do need to jump the yellow/black striped wire over to that connector but the green/black striped wire needs to be pulled and taped up out of the equation.
the yellow/black wire is for the high beams of the h4 and that green/black wire is for the low beam of the h7. you don't want to jumper those two wires together.
a picture is worth a thousand words.Thanks for the help, you figured out what I did better than I did.
good to know. and understandable.I do plan on soldering up and wrapping up the connections, but wanted to test out the connections before installing back into the fairing.
Do you mean the low beam cable that the bd43 mates up with?
so since the old ebay links are all dead, where can I find the angel eye HID kits?
Because I,m way to lazy to read all through this thread again ,lol
What ballasts did you guys use ?
I,m ordering my projectors tomorrow :cheer:
I used the slim ballasts.:thumbup:
