So, in preparation for putting my bike into hibernation mode, I decided to 1. change the oil, 2. stabilize the fuel, and 3. put the bike up onto it's paddock stands.
1. Got the oil pan drain bolt off no problem. Used bd43's walkthrough as this was the first time that I've changed my own oil on this bike. I had to take of my sub-cowling in order to use his tinfoil trick. Drained the oil, no problem. Went to change the oil filter (which was replaced at my last oil change ~ 3000km's ago at the dealership :spank and the damn filer wouldn't come off. I tried a strap wrench, and couldn't get enough space for leverage, due to the kick stand being in the way. Removed the kick stand and there still wasn't enough leverage. So, I tried a number 5 oil filter wrench from Canadian Tire. It split in half. So I went back and got 2 more. One split in half again. The other I drilled a self tapping screw into, and the into the filer, and it split into 3 pieces at the screw hole. Then I tried a slip jawed filter wrench. I succeeded in in denting the hell out of the filter, but didn't even loosen it. By now I was getting a little PO'd. Finally I hammered a screwdriver through the filter and tried to twist it off that way. I ended up breaking the handle of the screwdriver (not the metal bit, but the rubber/plastic part). Tried a larger screwdriver and finally got the damn thing off!
Total cost - three #5 filter wrenches broken, one Master Craft screw driver broken, one useless slip-jawed filter wrench, and one useless strap wrench. :banghead:
Got the new filter on, and filled the bike back up with Mobil 1 Synthetic oil. Took me ~ 3 hours start to finish (including a drive the the CT store for another #5 wrench).
2. Had to hand fill the bike from a gas can as it's too cold here to ride anywhere safely (today was a high of 3 degree's Celsius). As I was pouring into the funnel I ended up splashing fuel on the tank and front fairing. After I got the bike filled up and added the stabilizer, I decided to take it out of the shed and give it a quick wash to get the spilled gasoline off. As I was taking it off the center-stand it got a little sideways on me, and I ended up dropping it onto it's right side. How ticked was I??? :rant: Big time! Got the bike back up, cursing up a storm to find not a single bit of damage (thanks to Motovation Swingarm and Frame Sliders and the new HVMP bar ends). I mean nothing, zip, nada. Not a scuff, dent, scratch, nothing. So that improved my mood slightly (I was still pretty embarrassed). Got the bike all cleaned off and put it back into the shed, plugged into the trickle charger.
3. I had ordered a set of paddock stands ~ 1 month ago. Apparently they're on back-order. So, I put the bike up on it's center stand and had my wife push down on the rear end. I then took some pieces of 2x6 and 2x4 that I had cut for this and stacked them under the front forks. Once I got enough height I placed a piece of pine 2x4 as the last piece directly under the fork (so it won't dent/scratch the fork). Got it all balanced so that both the front and rear wheel free spin, and should not get any flats spots over the winter. Now she's good to go for her winter hibernation.
Probably should have put this in the rant forum...but, it's kinda informative, so...
