Not that it's any indication of my street skills :spank: but here's my BT023 rear with 6100 miles.
Yeah, here's my tires now...I mean naturally I'd wanna push better tires more but I'd probably not change my riding too much.Yup, those are the Q3s I told you about. They're good for at least one more track day, so they're staying on. Notice that the center is basically brand new. The sides all the way at the edges.. hopefully you'll never be riding on those on the street.
On my track day I meet an old friend. Later that evening he was bragging about his knee puck being ground up from dragging his knee. I saw some pics from of him... his head was on the wrong side of the bike but ya... his knee was way down there. LOLI agree with Erci, putting a knee down on the street is kinda stupid.
My 1/2 stips get me through the mountains just quick enough![]()
The final resting place of the S20 f @4600 miles
What strips?
When i mentioned "moving the lower body", which was the post Erci commented on, i didn't mean putting a knee down on the street, i just meant moving your arse a little bit towards the inside of the turn.
It is something i enjoy doing in the twisties, but i don't put my knee down.
Combined with a good head position it can really diminish your lean angle without the need to drag a knee.
Nothing wrong with that. Just make sure you're also leaning upper body at least as much as lower or more than lower into the turn. Otherwise you're crossing up.
Sent from my GT-P5113 using Tapatalk
Hmm.. any chance the suspension is too soft for you? Did you slide fork legs up?
I barely had anything left on either side on FZ6 and never ever scraped. :don'tknow:
^^ likely a combination I'd guess.. .. ..
The only time I've drug bits is in a banked corner going in REAL HOT! It just pancakes the suspension. Thankfully not enough to bounce off the road, but coupled w/lean angle was enough.
Setup is everything... PS - running stock spring on the rear and 0.83kg/mm (R6 fixed rate springs/forks) up front with the tubes up 10mm. Point: I don't drag parts and run fairly aggressively at times.
Look into setup (Sag is starting point) and rider style....
And we don't ever wanta do that!Nothing wrong with that. Just make sure you're also leaning upper body at least as much as lower or more than lower into the turn. Otherwise you're crossing up.
Oh wait; never mind. :rof:
Stock fz6 suspension is too soft unless your a tiny Asian. I now take off the side stand before any track day since it always scrapes. You can hang off like crazy and it'll help but eventually it'll scrape.
I'm stock aswell and find it fine. But I'm on terrible Yorkshire roads, so a little softer is probably necessary. And I'm no lightweight at fifteen and a half stone.As posted it the stock suspension.
I don't go to the track, none any near by short of Daytona, 6 hours away.
I'm happy with the suspension as it sits, suits me fine, but tks.![]()
Since you have brought up the subject of the sidestand, after 98,000 miles, here's a picture of mine. Compared to yours, I'm missing a lot of meat, and mine has become more of a knife.
My peg feelers has either grinded or broken off. They are missing, I still have the original pegs. The rubber is wearing down to the aluminum.
